I m using my friend's boat for the summer and so I decided to give it a much needed tune up/TLC.
The boat was rented out 2 years ago to one of his friends and I don't think they did anything but drive the **** out of it and return it at the end of the summer. Last year he went to use it and it overheated instantly. It parked all last summer with a full tank of gas. Fast forward to last month, I got my hands on the boat and right away I took the impeller out and found it in chunks and replaced it. I also did an oil change, new oil filter, new fuel filter and spark plugs. I tested it out for an hour or so and everything was great except when I give it about 60/70% throttle, it bogs BAD and rpms dip up and down. I assumed it was the gas, I removed the gas tank today and drained all the fuel. I added a bout 8 Gallons of 92 Shell gasoline and nothing was resolved except for the better fuel. It only happens when the prop is engaged.
I took the carb out and brought it over to a friend's shop where they took it apart and gave it a quick clean. One thing they told me is that I should get the carb rebuilt if the fresh gas doesn't fix it. The circular cup connected to a spring (in side the carb) was a little dry.
I understand there's a lot more information needed to correctly diagnose this problem (fuel pressure, timing, spark tester) but I was hoping if anyone had a similar situation or knows what I should do next.
When I got home today I removed the air filter and looked inside the carb and saw a puddle of fuel in each corner. I have a feeling it has to do with the carb.
Heres a video to maybe explain things better.
http://www.youtube.com/watch?v=3kD8qr7qvJY&feature=plcp
I don't know much or anything about carbureted engines but I m not mechanically inclined when it comes to FI engines and I m always down to learn something new.
