hey guys. replacing my lower shift cable on my 1979 mercruiser 898. got everything off and gonna start installing the new stuff but have a few questions. does the washer under the new lever i am gonna put on need to b replaced??
also I see this plastic washer here between the shift shaft and the bell housing. is it supposed to be there?? I cant seem to find part number for it. also if I put it on. the lever has no up and down play at all and is hard but can be turned. if I take it off, there is a little play and it turns nice and smooth.
also which seals are needed to prevent water from going thru the shaft into the lever?
thanks!
thanks!
