Provincetown boater
- Jun 21, 2010
- 16
HI,
I just got my 1985 mercruiser 170 running for the season. Toward the end of last year I kept having to add coolant almost every trip. So after running the engine for about 45 min I shut it down and started searching for leaks. I found a tiny pool of coolant in the front under the water pump cover. Aha I said let me see if these bolts need to be tightened. Bad move After just an eighth of a turn coolant started to really leak bad, I backed the bolt off and the leak backed off.
Ran the engine again and I do seem to be getting a drip.
Do I need to replace the gasket? or is it normally not supposed to be to tight?
Thanks
Pete
Thanks
Pete
