That bolt hole is commonly used when installing a new fuel pump. Put a bolt in it to hold the push rod in place, remove bolt after pump install, then replace with a 1/2 inch long bolt with rtv on the threads.
Wow! learn something new everyday! I wish I woulda known about that bolt trick BEFORE I changed out my fuel pump!!! Maybe next time.That bolt hole is commonly used when installing a new fuel pump. Put a bolt in it to hold the push rod in place, remove bolt after pump install, then replace with a 1/2 inch long bolt with rtv on the threads.
