rebuilt 1983 470 alpha one. i got to test run the boat in the water all went ok just a couple of things. charging system went ok(i did the conversion). the oil pressure went to 80 lbs at the beginning but then it went to 40lbs idle 60lbs WOT after it got to operating temperature. the temperature would not go above 125-130, i have a new thermostat and sensor installed. the boat at WOT i got 35 mph at 3500 rpm. does anyone have a comment on the oil pressure and temperature?
