working on a Mercruiser 3.7 and its over-heating. had it out on the water recently before the problem was detected and shortly noticed that the heat exchanger was pouring out water from the back of it [back plate]. took the plate off which seemed to be pretty much only finger-tight to inspect the plate and gasket. i had the plate off while the engine was started to see if water poured out like i thought it would, but nothing came out, so i thought it might need pressure. i put the cap back on and i also had the exaust pipe off too and thought water might flow out of there as well but again, nothing. it also dosent SEEM to be sucking up water from the lower unit [was in a container with wate]. i have worked on a few boats with water that flows though the manifold and out, no self contained units like this one... could use some help.
