I?ve got a strange problem with my Mercruiser 3.0 -07. When I check the timing it won?t stay stable. First I figured that I was because it was because of the advanced moving because of a little bit unstable idle.
When I checked the maximum advance it should be 25 BTD if I don?t remember it all wrong. But when I set the timing light to 25 degrees it jumps between 12 degrees before and 0 (37 and 25) BTD.
Anyone got any suggestions on what that could be wrong?
