iDrinkMolson
- Jun 20, 2012
- 4
Hello everyone, I would appreciate any help you can provide with my problem. I think I fried something, possibly a fuse or another circuit breaker, when using a battery charger while battery was connected in boat. Manual that came with it says to check TKS fuse, but it doesn?t say where it?s at.
2007 Mercruiser 3.0L TKS alpha
Model: 41110E5UT
Serial: 1A015520
In 2008 Bayliner 192 Discovery
Symptoms:
Turn key, get nothing, no audible alarm sound, no power to gauges, no solenoid clicking, not turning over.
Accessories work, horn, depth finder, trim motor (but not trim gauge).
Sequence of events:
First, battery was dead ? used jump starter to start it. Disconnected jump starter, ran for about 15 minutes, turned off for minute, started up on battery. Battery showing about 12v.
Connected battery charger on fast charge for about 7 hours while still connected in boat. (started to rain) Then removed battery from boat and continued to fast charge until it indicated charge complete. Battery shows 12.7v.
Installed battery, now won?t start with above mentioned symptoms. Tried jump starter again, same thing.
Checked/Fixed:
Found main 50a circuit breaker tripped (yellow arm out), reset it, still won?t start, etc. Did not trip again.
Checked all fuses under dash.
Checked 1 each of 15a & 20a mini fuses above and to rear of engine.
Kill switch in RUN position; gear shifter in neutral.
Checked fusible link on Starter, nut was very loose that attaches both cables to starter, tightened that, but no change. Fusible link looks good too.
Thanks,
Jeff
Model: 41110E5UT
Serial: 1A015520
Symptoms:
Sequence of events:
Checked/Fixed:
Thanks,
Jeff
