joewithaboat
- Jul 3, 2011
- 1,172
Re: Performance of my 383 stroker!
Unless the c/r, heads, intake, cam, injector size, fuel pump etc... are all the same as the Mercruiser 383 that tune is not optimal and is probably why it is not performing well.
If both engines, your old 350 & new 383, were exactly the same except for the stroke. The 383 would need a little less timing, a little more fuel, have quite a bit more average torque (because it would come on sooner), make a little more hp.
You need to be able to compare exact specs of the merc 383 and your new 383. You will probably need a custom tune.
