13crazyhorse
- Apr 4, 2010
- 147
I have a 79 mercruiser 470 with a Rochester 2 bbl carburetor. The boat has been running perfectly all summer up to this point. My son went to use it the other day and it wouldn't start. He tried again about a week later still nothing. Turned over well just wouldn't start. So I went up this weekend to check it out. After trying to start it with no luck I could hear gas running into the carb after I tried to crank it over. I removed the carb and the intake manifold had about an inch of gas in it. I dried everything out with towels, removed the plugs let it air out and reinstalled the carb. The engine started right up and ran for about 30 seconds then quit. Same thing gas running in the carb after it stalled, manifold filling up again. I removed the carb, got a rebuild kit and went to my camper and rebuilt the carb as best I could. I'm a long ways from home so I couldn't blow everything out or clean good with solvent. I replaced everything except the pump assembly because the kit was missing the clip to hold it on, not quite like the old one. I took the carb back to the boat reinstalled and exactly the same thing happens. I also tried adjusting the float with no change. Anybody have any suggestions on what I'm doing wrong or missed? The gas is running in towards the bottom of the carb below the jet area and continues to run in for a couple of minutes after turning the engine over. I'm home now so can go through it again and also install the pump assembly and blow everything out. Thanks for any advice.
