Mike921056
- Jun 23, 2012
- 6
I have a 1990 5.7 mercruiser and cant get spark. I put a new coil and a sensor in the distributer the old sensor had two wires on it and the new one came with three one green/white and one red/white and a black the old one didnt have the black so i grounded the black to the block. There is a green/white wire coming from engine harness that was spliced into the old sensors green/white wire should i splice it in the new sensor or is it supposed to be hooked somewhere else? I also disconnected the shift interuptor to elimante that ad my problem. I have 12a volts on the positive side of the coil and nothing on the negative when key is on or turning over. There is 12a volts at the red/white wire on the distributor. I am pretty much lost at this point i cant seem to get any spark. Only thing left i can think of is the thunderbolt 4 module on the riser but its kinda expensive any ideas what i should do or try?
