I have a 1973 165 I6 with milky oil
Freeze plugs are intact
No water in the bilge
Spark plugs look normal - None have been fouled, steam cleaned or anything out of the ordinary.
Water is not pouring, squirting or spraying out from anywhere that I can see
Ran up and down the river for at least 30 minutes and only saw the oil rise about 1 MM on the dipstick.
Engine ran a little rough (previous owner used autolite plugs)
Water temp is 140 - 145
Oil Pressure a little too high for my taste
Question is Cracked Block, Blown Head Gasket or What?
