how do I replace the cable going into the lower unit that engages my propeller?
mikenfaith
I have a 1976 mercruiser 140 hp the cable runs from the top behind the engine on top of some sort of shift mechanism into the propeller side of the engine...........well my cable is not moving in or out its stuck and I dont have the slitest idea how to change it..............any suggestions or manuals or walk throughs? Thanks all in advance for your help
Re: how do I replace the cable going into the lower unit that engages my propeller?
how long have you had this boat, and how old is the cable, and when was the last time you pulled the outdrive off?
achris
More fish than mountain goat
Sounds like you are going to need these....
Engine and drive service manual -> https://docs.google.com/open?id=0B1TAvwZ3TjhfOTI5OTMyZTMtNDNkZi00MDAyLWE5MTYtMTI5N2MyNDM3NjZm
Download and SAVE this... It's you new bible...
And these might be some help too...
Links to videos
Removing drive: http://youtu.be/w3O63YTOhn8
Installing drive: http://youtu.be/aGVrY4cWiDA
Shift cable adjustment: http://youtu.be/-s_tgevX2aI
HTH,
Chris......
mikenfaith
I just purchased it and have never had the outdrive off...........the guy I bought it from (on craigslist) claims he had it out on memorial day seriously doubtful!
Being the boat is a '76 you may have the old style shift cable still. They have been change to a newer style that threads into the bellhousing from the aft end, instead of the front end of the bellhousing.
If your drive is original, it would be a MC-1
If you downloaded manual 2 From Chris ^^
looks like the shift cable removal is on page 6A-38
and installation is on page 6A-45
