davidsimmons
- Jun 22, 2012
- 2
so i get this boat starboard engine has 90 psi fuel pressure i put port engine pumps and reg in starboard problem solved get new pumps put in port eng both run fine now starboard motor runs at 36 psi and stalls i watch fuel pressure go to 0psi i can fill the filetr bowls and it restarts and runs at 36 psi until its out i disconnected the fuel line and put it in a can to eliminate tank check valve but it does same thing removed pumps and filters dont see anything wrong have 12 volts and good ground i didnt have any problems with port side so my starboard had two problems high pressure and stalling ??? the low pressure pump doesnt seem to be pulling fuel from tank or a can ???its running out of fuel???
