Hi Everyone,
I have a 1998 3.0L with a Merccarb carburetor. I've been chasing an intermittent problem for 2 years.
The engine starts easily, idles fine initially, and runs great at cruising speed.
Occasionally, however, after running at cruising speed for a while (after the engine is good and warmed up), when I back it down to idle, it'll idle rough for a while, and will eventually die after a few minutes. This doesn't always happen but happens frequently enough to make my wife nervous about the reliability of hte boat.
This happens even when I gradually come back to idle. It'll normally starts right back up with no problem and will idle fine after that.
Last summer, I rebuilt the carburetor making sure I set everything to specs (float level, float drop, idle mixture, idle speed). After the rebuild, I haven't noticed any real improvement.
If the boat idles fine when cold and idles fine when hot (sometimes but not all the time), what should I be looking for?
