Re: Mercruiser 3.0 rebuild - Master rebuild kit or just the basic?
My questions are designed to evaluate your skills for the task you ask about.The only stupid question is the one NOT ASKED.
Your response tells me you have never rebuilt a motor or drive to ask this:
"I am rebuilding my 1979 3.0. The question I have is, should I get the master kit, which includes new pistons and new cam shaft and lifters, or can i get by with just the basic kit that includes just the bearings, rings, oil pump and gasket set? "
You need to know sizes to order parts and you can`t do that untill everything is measured. Cams may or may not need replacing depending on the wear and if you kept the lifters matching .Cams and lifters must be replaced as a set, or reinstalled in their same positions to avoid flat spotting the cam.You can get pistons from STD. to .070 oversize,and the ring size must match the piston size.
You omit honing and crosshatch questions in relation to finished bore size.
This is somwhat of a rant but.............................
