vogelBoats
- Jun 20, 2012
- 7
Hi all,
I was pulling into the marina and boat was running and shifting fine all day then it started stalling. I pulled up to the dock and was unable to get the boat to go into gear without it stalling. I had to get towed to the trailer and got the boat off the water. Upon further inspection, I noticed the lower shift shaft had dropped about a half an inch causing me to be unable to shift the boat into gear. I got a pair of pliers and squeezed the lower and upper together and it fixed the problem. boat shifts fine now and doesnt stall anymore. I'm afraid that it will happen again. What causes the shift rod to fall down, and how can i fix it? Thanks.
