5.0 mer i/o that cuts out
glenn wolin
I have a 1996 mercruiser 5.0 mpi. The engines runs fine until I put put it into neutral. It then cuts out and turns off. It will then take quite a while to restart, while I shove it into gear quickly. It sounds like its starving for gas when I crank it over. Any suggestions.
tpenfield
Re: 5.0 mer i/o that cuts out
Welcome to iBoats . . . this threads should be in the Mercruiser forum (not the Mercury outboard Forum) Hopefully, the moderators will move it at some point.
The issue sounds like it could be a problem with the shift controls . . . there is some sort of 'shift interrupt' thingy that prevents shifting above idling speeds, etc. My thinking is that as you futz with the controls while trying to re-start it then relieves itself of the interrupt mode and off you go.
Sorry for the technical terms of 'thingy' and 'futz' ;)
