Finally got my engine back in my 1983 Sea Ray 260. I opted to find a used engine for the replacement, the engine i got was a few years newer (88~89 350 magnum). Engine started and ran great but as i ran it on the muffs at about 1000 rpms the coolant temp gauge just keeps climbing to the red line then i shut it off. My observations are...There is lots of water flow out the back of the transom but none out of the prop hub, i can hold my hand under it and its really warm but not super hot. I took out the thermostat and tested it in boiling water, its fine. Is it possible that the sending unit is different from my old motor and maybe not compatible with my gauge? Thanks
