26aftcab454
- May 12, 2009
- 1,510
Re manufactured 350 2pc rear main seal--5qt original oil pan damaged/replaced with what I thought was a 8qt pan--The 2nd photo shows the Windage Tray and the Dip Stick is even with the bottom of it. Added TWO 5.1 QT bottles of oil and still nothing on dip stick? How far below oil pan gasket should the oil level be at? We installed a lower/extended oil pick up that is within 1/4" of the bottom of the pan. We removed the dizzy and pre oiled whit a drill and had oil to the heads.
