Merc. 140 sounds like a lawnmower
SSTKO81
Recently took my 140 out for a spin. Ran great up to 2000 RPM then Sounded like a briggs and Stratton. -sounded like it was coming from the carb. -backed off the throttle and ran fine for an hour. -just sounds terrible and has no guts after 2k. Ever seen this before? Thought maybe a bad carb gasket...
QC
Re: Merc. 140 sounds like a lawnmower
The real question is does it cut the grass?
:p Sorry. Couldn't help it :redface:
Don S
What have you done to it since it last ran ok, anything?
SSTKO81
Well, it will certainly cut pond grass....
When I put it up last fall it was making this noise. Took the intake off and replaced it because I found it to have a crack between the water jacket and exhaust plenum. -That seems to have helped, but obviously the problem is not fully cured.
I thought it could be detonation, but it seems to start and run fine at idle and low RPM, though it is a little shaky.
It's got new plugs, wire, cap, rotor, points and even the coil. Checked the timing and dwell; they're perfect...
Ayuh,.... If it's goin' Lean,.... it'll detonate, 'n have no power, under heavier loads....
SSTKO81
Welll I'll try richening up the mix a little. -just a thought, guess a bad carb gasket would cause similar issues...
Gasket i've got on there is SUPPOSED to be reusable... :facepalm:And was reused after taking the intake off. I'll give it a shot and see what happens.
SSTKO81
Put a new carb gasket in and richened the mix but it still sounds terrible. Not holding idle very well either. I can set the RPMs at 1000, not touch the throttle and for no reason it will suddenly bog down to 400 and violently shake like its gonna die. -barely tap the throttle and it will shoot up to 1100 PRM and run fine. -still not making the briggs and Stratton sound till I get up over 2000 rpm
Don S
Your mixture adjustment is for idle only. Has nothing to do with 2000 rpm and above.
What shape is the plug wires in? When was the last full tuneup? Compression check, timing check. What year is your engine, is it points ignition?
If it is points ignition, hook up a dwell meter and see if it changes dwell at higher rpm.
SSTKO81
Last full tune up was last spring. And its got less than 4 hours on it since then. But just for giggles I put new plugs in and cleaned the arrestor a couple weeks back. The wires and points were replaced last spring and I've checked dwell at startup, but not sure how to do it at WOT. what would a change here indicate? I keep hearing detonation detonation, but I guess I don't know how to increase fuel in the upper RPM range...
Don S
I don't see detonation as the cause at this point.
Hook your dwell meter up and run the engine at idle, record the dwell. then raise the rpm up and check it. Should be the same.. Worn distributor bushings causes it, or week point springs.
Has it ever run right since you put new points in it?
achris
More fish than mountain goat
Start with a compression test... What's the compressions on each cylinder?
SSTKO81
yes, when I put the points in last spring i took it out and it ran like a cat on fire for about 2 miles out of the cove, then this "lawn mower noise" started happening and I lost my top end. I limped it back home and found the exhaust manifold to be cracked. -hasn't run right since.
Don S
The manifold is intake and exhaust. Have you replace it since you know it's bad? Have you checked the compression yet?
SSTKO81
Replaced the manifold and I've checked it thoroughly for leaks (visually and audibly). I haven't had a chance to do a compression check yet. -I'm hoping I'm not looking for a bad head or head gasket; the one bright spot here is that it's not overheating at all and there's no milk in the oil... I've considered maybe a valve or lifter may be off but that wouldn't account for only showing up at higher RPMs... I'll check the compression and put a dwell meter on it and let you know what I find.
stonyloam
I am with Chris on this one. Would not be surprised to see a bad cylinder or 2. You might try pulling the plug wires one at a time at idle to see if you have a weak cylinder.
SSTKO81
Took my boat to the mechanic; did a leak down test and found slight misfire on # 2 and no compression and # 1. So now we're pulling heads... This doesn't sound like its going to be fun... Or cheap.
Has anyone had a similar problem like this. Mech. Thinks its probably a bad valve (don't have results yet). What causes that?
SSTKO81
result of this was cracked head between valves on #1. replaced head, gasket, one rocker arm and we're cookin' with napalm. thanks guys!
nola mike
Always nice to see a successful update!
QC
Yes ^^^^ thank you!
