Stevens520
- Jul 26, 2011
- 250
Just did a good shakedown run on my boat today, and had a few issues: Boat idled great at first, took it out and opened it up (discovered problem No.2) after that it idled very rough to the point where it was stalling while at idle. Also smelled a lot of fumes while idling. Issue 2:When up on plane, could not turn steering wheel; steering came back to normal after slowing down. Did notice some hydraulic smelling oil coming out of drain hole with bilge water.Bilge was cleaned out last week after changing fuel filter, no oil found while doing so.Problem No.3: Starter has an intermittent problem of spinning, but not engaging. This has happened the last 2 times at the launch ramp. Usually it takes a couple of tries, but it eventually it does grab, and start. Boat is a '75 Starcraft Cheiftan with original 888 Mercruiser. Any help will be greatly appreciated.
