LIbottomsup
- May 5, 2012
- 4
I have a 1985 mercruiser 4 cyl with alpha one outdrive. Problem is I hit ground and now am getting no prop response at all. The boat does not even seem to be shifting into gear. There is no feel of going into forward or reverse. Not really sure where to start. Prop turns by hand in gear in the correct direction and then makes kinda of a "klunking" sound in the other direction. The shifter seems to be working fine but when I throttle up the engine just revs and the prop does not turn either direction. Any advise on where to begin is appreciated. Thanks in advance.
