Just finished installing 4bbl GM intake manifold and 4bbl edelbrock 1409 carb on my 2008 4.3 alpha one. Putting it through some trial runs last night at home with the dog ears attached. Ran good, timing may be out a bit, but my problems started when I attempted to turn off the engine. Put the key to the off position and remove it but engine runs perfect. Sat around for a few minutes thinking it was going to die when the fuel from the carb was used up....but it never did. Kill switch didnt even work. I had to manually idle it way down with the idle screw on the carb till she stalled. Then i still hear a buzzing sound from the fuel pump. I had to disconnect the fuel pump at the harness, to kill it. The pump was very warm to touch, curious if this is normal? I take the the flame arrestor off and see my choke on the carb is wide open, and some condensation or exhaust coming from the carb....thinking this is a timing issue possibly?? Let it sit for the night do a visual this morning choke is closed now and hooked the fuel pump back up to the wire harness and it was fine. Anyone have any idea why my fuel pump or engine would not kill with the key in the off position?
