natsgrampy
- Aug 31, 2010
- 172
About to put my mercruiser outdrive back on to the boat. It is an '87 Sea Ray with a Mercruiser 3.0.
I have all new gaskets and seals which came with the shift cable kit. There seems to be 2 gaskets for the bell housing in the kit, are they both used in the install?
There is also a ring / seal which doesn't match anything I removed when I replaced the bellows etc. Is there a hidden ring/seal I can't find?
Lastly, do I use any adhesive or oil on the gaskets or seals.
Thanks again for all the help here, I hope to have this on the water this weekend.
