Did Carter ever use just a check ball and spring in the main discharge nozzle circuit? All the pictures i see show a check ball and brass weight. When I took the carb apart last night I ended up with a check ball and a small tapered spring.
Yes, under the accelerator pump plunger...
I'm talking about under the main discharge nozzle (squirter nozzle on primaries).
