whats holding my y-pipe in?
jonesy1186
Same story, replaced lower shift cable, found exhaust shutters remnants. Decided to replace, have moved motor forward enough to get the 4 bolts off y-pipe but y-pipe wont seperate from transom. Do have some slight twisting movement, but thats it. I'm assuming the whole thing needs to come off, it's the old three piece style. ( '77 351 ford ) Also assuming once I get it off it will be obvious where the new ones will mount, am I right?
achris
More fish than mountain goat
Re: whats holding my y-pipe in?
5 bolts...
jonesy1186
Was afraid of that! Can't find #5 bolt, any links to a picture of bolt pattern out there?
Thanks for the reply.
Don S
attachment.php
jonesy1186
Dohh! The allen head. Felt it, but couldn't quite see it. Glad i didn't go crazy with the pry bar! Thanks guys!
jonesy1186
Ok guys, pipe came right out. But I'm not seeing anything obvious as to where the flappers go ?
Don S
#22 is the shutters, one in each side of the Tee (#24)
attachment.php
haulnazz15
One flapper goes on each side of the "T" in the center section. There should be some plastic rings that set in a groove on the inside of the pipe. Make sure you install them so that they would close when water comes from the inside/exhaust flows out freely.
jonesy1186
Thank you Don and haulnazz, you guys are great to have around.
