monterey98
- Sep 17, 2010
- 54
hey guys i have a 1998 monterey 24ft Bow rider...engine s/n is 0L025412, alpha one outdrive, when winterized there is a oil leak, 1qt maybe 2qts low. but when using in summer time a lot less, what do i have to check to find this leak?
also when i'm using the boat, notice bilge pump coming on automatically pushing water out every time i take the boat out, i don't know if is water from the rain days before or something leaking inside, when i check the engine on idle can't find a leak, engine runs fine and smooth.
Don't know if the oil leak on the bilge and water on the bilge pump got relation. On the dip stick show a clear/clean oil, no water....sometimes on idles oil pressure goes under 40 and when hot wot 40psi all the time.
thanks guys.
thanks guys.
