Hello,
I have a Campion boat with a 3.0 mercrusier alpha one. I need to replace the engine due to cracked block.
What years or models of engine will be a direct fit?
Thanks
thanks for the reply, it is a year 2000
Ayuh,... That's current production,.... '91, 'n up, should be plug, 'n play...
i'd definitely stick with 91 and up, the earlier engines have differences that will make it spendy to adapt, flywheel, coupler, rear mount.
If I buy a donor boat from 1990, how difficult would the swap be?
