redgoat
- May 23, 2010
- 102
After 45 years of running my Sea Ray on a conventional points and condenser ignition, I am installing a Sierra electronic conversion for 4 cyl Delco ignition. My Mercruiser is a 4cyl, 153 cu.in., 120 hp engine. I have got to to the final instruction where I must do something with the red wire from the ignitor. One diagram says to connect the red wire to the positive side of the coil. The other diagram says to connect the red wire to a ballast resistor which is itself connected to the coil. My question is if I had a ballast resistor, wouldn't its presence be noticable near the coil? My coil is a standard oil-filled coil with markings 12v use with external resistor. I have never had a coil issue ever with my old standard ignition. I'm thinking I should just connect the red wire to the positive side of the coil and start the engine. Does this sound correct?
