doodeesdaddy
- May 29, 2012
- 3
can anyone help? I have 1990 187 xl eclipse I/O with a 4.3L v6 mercruiser with thunderbolt IV ignition the motor isnt the same that came with the boat older by a couple years i was told. Starts good. Idles good. Runs good up to 2500-2700 rpms then fluctuates up and down in power and speed. checked compression good in all cylinders got spark. problems noticed vacuum leak at base plate of carb cap and rotor dirty ordered those. What should i do first for losing power and speed?
also outdrive has up and down movement by hand really sloppy........any suggestions would help thanx
