merc120_81
- Jun 20, 2011
- 92
hello all,
I have a 1981 mercruiser 120 io/ the stern drive S/N is 5804180 and transom plate s/n 5776812.
1) what model sterndrive unit is it (pre alpha.. alpha r/mr etc?)
2) What transom kit (Bellows, gimble bearing, cooling hose, etc) Would I use on it?
3) would a dry rot/small leak in the hose between the transom plate and sterndrive unit (cooling water) cause highspeed overheating? idles all day no temp rise, up on plane any rpm boat overheats ( it hits 170/180 and I shut it down to an idle to cool before going anymore.
THANK YOU!
THANK YOU!
