Re: mercury cruiser 170hp 3.7 voltage regulator
If a marine shop (any shop for that matter) tells you to remove a wire with the engine running, DON'T go back to that shop!!!!
Just do the test I told you, check the battery voltage before you start the engine. Run it at 1000rpm (in gear or neutral, doesn't matter, 1000 rpm is 1000rpm) and read the voltage on the battery... It should rise to about 14 volts and stay there... If it doesn't go up or it goes up too far, then the system is not working and needs to be replaced....
Chris.........
Don't worry about red wires or orange wires, just on the battery....
If the voltage regulator wasn't dead before you pulled the battery cable on a running engine, it probably is now....
