Anyone know where I can find a wiring diagram for a 165 merc? Mostly for the ignition system.
It will start with the key off or on. When you turn the key to the start position a solenoid above the starter clicks but you can get it to start and run by crossing the starter but you can't get it to turn off.
Also none of the accessories work such as the blower, bilge pump, or navigation lights. I have that narrowed down to peer somewhere after the fuse panel though.
