I am sorry if this has already been discussed but after spending the morning searching I still have not found a solution. I have a mercruiser 120 on a 1978 Drifter that I am having some issues with. When I pump the throttle I see gas squirt but it won't turn over or even kick like it has fuel. If i spray some starter fluid or carb cleaner into it it turns right over and runs like a champ smooth as can be. I can leave it running for as long as I want and it doesn't sputter or die. If i immediately try starting it after I turn it off it starts right back up. If i wait until the engine cools down (few hours or over night) i cannot start it again without starter fluid.
At first i thought it was the fuel since I saw it squirting but not starting but would it still be considered a fuel problem if after it starts it runs like a champ? It almost seems like the spark plugs are not igniting the fuel until the engine is warmed up. I was going to take a squirt bottle down with some fresh fuel to check to see if that makes a difference. Was also contemplating taking some new spark plugs down and see if that does anything. If anyone has any suggestions please let me know. it would be greatly appreciated.
