Ok, I have been reading for hours about lower shift cables and interrupt switches and other things that could cause this problem. I wanted to ask other Starcraft owners if they have any first-hand knowledge on this issue. I have a 1969 Holiday V 18 ft I/O with the MerCruiser 120. It will go into reverse fine, but the second any throttle is applied, it dies. As I understand it, if it was a problem with the shift interrupt, it would die going into reverse, not when the throttle is applied. Any thoughts or ideas are greatly appreciated.
