I am tearing apart a 1989 Alpha one to do a bellows job. while in there I am going to replace a trim switches, and gimbal bearing. I also noticed gear oil in the u-joint bellow so I am going to look at the yoke but I don't have the special tool yet to tear it apart.
My drive has the two bolts holding the trim unit wires. How the heck do you get to the top bolt? I imagine there is another special tool needed.
For the gimbal bearing I followed this procedure to remove it. Can I just pop the middle of the bearing out of the new bearing and put it in? http://www.mercstuff.com/gimbalbearing1.htm It seems that they should be paired.
Lastly, what are the chances my yoke will need the rolling tourque or will it have the retaining ring? Before I buy the special tool and then another special tool for the rolling torque, I may just take it to a shop to replace the yoke and seal.
Thanks
Thanks
