Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Gear Oil coming out of weep hole in lower unit
  • Gear Oil coming out of weep hole in lower unit
    Just wondering if this is a Seal issue? It started coming out the small hole soon after filling the gear case; normal filling by the bottom drain hole and pumping oil in until it came out of the vent hole.
    Any ideas?
    Thanks
    Mowers - Power Sports - Watercraft - Snow Machines
    http://audiessmallengine.net
    Re: Gear Oil coming out of weep hole in lower unit
    Hard to say. Drain the gear lube and pressure check the drive and find the leak.
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      Thank you for your knowledge, the customer also wants the impeller replaced (which I have performed on several boats with great success) so that would be a good time to check it over. I have never seen oil come out of that little hole. I have also replaced gears and other components in lower units, but this stumped me.
      • #4
        Originally posted by ASEAudie View Post
        .... I have also replaced gears and other components in lower units....
        Using the correct shimming tools and procedures according to the manual I hope!
        xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
        The world takes on a whole new perspective when viewed from 100’ below.
        1972 Bertram ‘Bahia Mar’ 20
        2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
        (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
        • #5
          Drive model?
          When will people learn that impellers require regular
          replacement and are not drive it till it pukes items?
          1984 Regal Medallion 195
          3.8 V-6 with the dreaded
          OMC Stringer Drive.
          2003 Avalanche w/Hypertech
          If it ain't fixable - don't break it!
          • #6
            Any ideas?
            Thanks
            I've got an Alpha one Gen 2 and mine has a very small leak out the weep hole. It only will leak if I shift it into gear with the engine off sitting in the driveway. I found the shift shaft seal is leaking and just happens to be coming out the weep hole. Take a look at the shift shaft and see if there is oil around it.
            • #7
              I haven't even looked at this unit as of yet, been really busy, I am closed on weekends so that I can play catchup if I don't go fishing. I plan on pulling this unit in and locking the doors; at this time I will start eye-balling this thing and hopefully get it figured out, I appreciate the ideas and will respond with what I find.
              Everyone have a great weekend.
              • #8
                again..... drain and pressure test there is a bad seal somewhere.
                • #9
                  i was just dealing with the same problem after a new impeler install, i replaced both top and bottom water pump halves then replaced the shift shaft bushing.
                  after a pressure test with a little soap i found the lower water pump housing was leaking, this was a new part but i guess these things happen.
                  so i replaced the lower housing again now all is well
                  thanks to all that helped in this post all good tips
                  • #10
                    Hey guys, new to the forum board here. I am having a similar if not the same problem here, I just purchased a 1995 Maxum 1800 Ski Boat.
                    Guy I bought it from stated, that he just had it serviced and had a new prop put on it and mechanic stated everything looked great.
                    When I got it home and parked it the next day I noticed a few droplets of greenish oil underneth the outboard prop.
                    Looked at it very close and it seems as if the oil is coming out 1 of the small holes right above the prop.
                    Is there an issue or could this just be where they had just serviced everything.
                    Any help would be highly appreciated. I am a 1st time boat owner so dont know a whole lot about boats.
                    • #11
                      You all have to drop your lowers & check the shift shaft seal. The seal has been the same since 1963 & since '91 been pushed into a plastic bushing. Replacement seals push back out usually. Replace the whole bushing & shaft assembly!
                      • #12
                        Hy dymd3z and welcome to iboats forums! I recommend you copy and paste your first post into a new thread started by you. Also provide as much info about your equipment as possible (model numbers, serial numbers, operating history, etc). It will then allow the forum to concentrate on you problem and it wont get lost in the other person's thread (also known as hijacking....pretty crude term, but it is what it is).
                        Best of luck in getting your issue addressed. I'll look for it in the new thread and I am sure you will get the personalized help you need.
                        Also, please go to the top of the mercruiser forum and open the threads called "stickys". They will provide you (as a new boat owner) with a wealth of information and links that you need... particularly you should download copies of the manuals for your engine and outdrive. If you are like me, you wont be disasppointed!
                        KTB
                        1990 Chaparral 20' w/ 5.0L, Alpha-1
                        • #13
                          KB, thank you very much, I made a new thread and I hope I can get someone to help me out. Again thank you very much!
                          Bo
                          KTB
                          • #14
                            I finally got a chance to remove the lower, drained the remaining oil and gave her a little pressurized air into the weep hole and crap came flying out past the shift shaft. All the seals could probably be replaced in this 1972 clunker. Just wondering if I should even attempt any repairs or just call the guy and say the parts are NLA. What do you guys think?
                            • #15
                              SEI lower for about $600 is even cheaper than stripping the box and putting new seals in... It's a 'no-brainer' for me...
                              Back to Top
