jcschrimsher
- May 1, 2012
- 4
I have a 1978 sea ray 240 sedan cabin cruiser with fly bridge with a 1985 260 mercrusier motor. I am having problems with the steering, it is very hard to turn either way. It does not matter if you are trying to steer boat from fly bridge or from below.. I have made sure the hydraulic lines are full of fluid...took the shifting rod to out drive a loose and still tight...attempted to grease and it will not take any more grease, did this on stern and has not help, makes no difference if boat is running ..the power steering does not effect the problem still very difficult to steer. Do you have any thoughts or ideas to what may be my problem and any suggestions ...I will very much appreciate any and all help.
