jimbojonesmc
- Sep 8, 2011
- 26
Any thoughts would be great. 1985 mercruiser 3.0 4 cylinder has a internal pecking/knocking sound coming from The front of engine around the timing gear cover after engine warms up on muffs or on water.
Constant sound never goes away…knocks at idle… knocks going up to a higher rpm …knocks at high rpm and knocks Coming back down to a idle. Does not sound like a rod or main. I have checked the following
Fuel pump (new)…valve adjustment…ignition timing...spark plugs...rocker arms...changed oil...distributor…push rods…lifters…have removed belt and to confirm it’s not the water pump or alternator. Engine has 135 lbs compression in all cylenders and 35 lbs oil pressure at a idle. Runs like new except for this knock.
I’m thinking cam end play or timing gears…any ideas??? OBTW this boat new to me so i have no clue
when it started making this noise.
Jim
Jim
