Well, after a few years of problem free charging- something finally went bad with my 470's notorious charging system. I've got 0 volts coming from either yellow wire so I'm not sure if its the VR or something else. Nonetheless, 3 bolts, 1 bracket, few nuts-washers, belt & a single wire marine alternator from a 165 6 cylinder - I've got it done.
Now, I removed the yellow wires only from the VR. I left the red and orange on there. I put the single wire from the alternator to the main cluster of + wires on my starter solenoid-the post the battery cable connects to. Will this do?
I am getting mixed reports whether I can run like this or if I should disconnect the red & orange wires and connect that to the wire going to the alternator. From the cluster of wires on the starter solenoid, at least one of them connects to the regulator.
I'd be much obliged for any insight.
