I have 218 ls Monterey with a Mercruiser 5.0. When I press the trim button on the contols the gauges ( Fuel and Voltage ) drop as if the key is off. I have a feeling that I have a grounding problem somewhere but don't know where to start. I put a volt meter on both batteries and am getting 12.8 and12.7 at the batterries. What wiring should I look at first the find the problem? The tilt trim works fine but pressing the trim button causes the voltage drop.
