Acquired my boat from my fathers friend who passed on recently. Original owner of a 1970 Starfire 190, with Mercruiser 165. Boat is like new and he kept it garaged and used in Lake Powell, AZ. He was a mechanic and rebuilt the engine in 2009. He took it out and put 8 hrs on it, the it never went out again since he fell ill. I have it now and have changed all rubber on the stern unit (bellows, seals, water pump, etc. New shift cable. I rebuilt the carb but really didn't need to because dad's friend had obviously done it. Regardless,, runs like a champ with carb dialed in and cables all adjusted. Oh yes, new oil, filter. New trim cylinders because old ones were shot. adjusted points gap and dwell, no problem.
OK, enough background, here is the problem. Checked timing and it's appx. 90 degrees off. Checked wire order, and they are correct. Tried to move timing mark where it should be (turning the distributor) and of course that is a no go. It's too far out. I have it set by ear and the engine runs great, BUT, I'm annoyed I get the timing exact since the mark if off or there is something I have set up wrong that I don't know. I know in a car you can have the distributor 180, but then it sputters and bangs and you know right away it is 180. The merc purrs, but only bad indication is that timing mark.
Any suggestions?
Any suggestions?
