Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
mercruiser ignition problems
  • mercruiser ignition problems
    ok guys heres what i have its a 1986 mercruiser 140, with points ignition, i have a problem with keeping it running. it will stall out on me after a few minutes on the muffs at idle, @650 rpm., i did a complete tune up to see if that would help and its still dying out on me..if i take a wire from the +12 side of the battery to the + side of the coil it will run great, whats the best way to isolate whats wrong? i disconnected my temp wire as not to burn out the points with batt voltage. i also have a mercruiser resister kit installed in the harness going to the coil.
    Re: mercruiser ignition problems
    Disconnect your boats fuel system at the engine fuel pump and hook up an outboard tank and see what it does.You could have problems with the fuel pickup, the antisiphon valve, hoses sucking air instead of fuel due to bad hoses or wrong clamps, plugged fuel tank vents or low spots in vent hose.
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      don, i cleaned the antisiphon valve, replced all fuel filters, installed a new factory mercarb, getting great fuel pressure, why is it if i hook up 12 volts to the plus side of the coil it runs better
      • #4
        You also did a tuneup. After you changed the points, did you set the dwell, and then reset the timing and adjust the carb?
        Don S.
        • #5
          don yes i did,
          • #6
            What is the voltage between the positive side of the coil and the block when it starts acting up?
            • #7
              You have made no mention of the coil. Did you change it. The coil is mounted close to the block and gets pretty hot after a few minutes. An intermitten coil will give you some similiar symptoms. If it is an 86 model coil it is due for a change. often mistaken for carb problems.Uncle Dave
              • #8
                i'll check in the morning and post
                • #9
                  coil has not been changed to my knowledge
                  • #10
                    You also need to check the resistance from the 'ON' side of the key switch to the coil "+". It sounds like you have a resistive wire going faulty. Does the engine slowly die out, or is running great then just die, like the key has been turned off?You say you have a restistive wire kit installed. Is this in series (in line) with the original or does it replace the original?Chris............
                    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                    The world takes on a whole new perspective when viewed from 100’ below.
                    1972 Bertram ‘Bahia Mar’ 20
                    2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
                    (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
                    • #11
                      Chris,it dies a slow, reistor replaces the original
                      • #12
                        thanks guys it was a bad coil, replaced it today it runs great now
