ImperialV184
- Aug 4, 2011
- 99
Iboaters, have a few questions here, i am progressing on my rebuild of my MCM 165, after several checks it appears like i am going to need a full rebuild and need to get the block to a machine shop. Have quite a bit done already but having trouble with the flywheel removal.
Anyone, know any tricks to getting the fly wheel off the Mercruiser 165's. I have the cover off, all the visible bolts are out on the coupler, it does not budge, do i need a puller for this? or just a lot of patience?
Also i am going to put the engine on an engine stand as well, do i just use the bolts that held the fly wheel cover on or do i need to get special bolts? I want to be careful since it is an aluminum block and use the right attach points. Never used an engine stand before.
With regards to getting the engine on the stand, i already have the head off the engine, but i will need to use a hoist to get the engine on the stand, do i need to put the head back on and use the original lift points or can i use the head bolts directly to the hoist chain. if so does it matter which head bolts i should use.
Thanks to all for any help. I am already learning a ton from everyone out here and could not have gotten this far without help.
