Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Water hose Alpha 1 gen 2 replacement.
  • Water hose Alpha 1 gen 2 replacement.
    Hello,
    How do I replace a water hose (part #32-860220 quicksilver) on the upper unit of the stern drive? Can it be pulled out? This is an alpha1 gen 2 out drive.
    Re: Water hose Alpha 1 gen 2 replacement.
    Ayuh,.... Welcome Aboard,....
    That hose is usually swapped out when doin' a Bellows job on the drive,...
    The drive needs to come off, 'n the bellhousing disconnected to get to it...
    If it were Me, I'd plan on changin' ALL the rubber parts, 'n the lower shift cable at the same time...
    • #3
      I agree,and when ordering the exaust bellows get the new style boot design it's much easier to install
      If you can read this thank a teacher.If you can read it in english THANK A VETERAN
