Hi,<br /><br />I've got a 1981 120 Mercruiser that has developed a noise in the flywheel area of the engine that sounds like a severe metallic "rattle". I'm familiar with automotive engines and would relate the noise to a loose or cracked flexplate on a car. I've been trying to work out an occasional miss in the engine and at first it would only do it when the engine was missing, now the noise is there all the time even under load. I put a mechanics stethoscope on the engine and it's not an internal engine noise and is loudest at the belhousing area. Is there any easy way to check for loose bolts or other problems inside the belhousing? Anyone know what this noise is and can point me in the right direction to look?<br /><br />Thanks,<br />Joe
