taterandpickle
- Nov 5, 2011
- 1
I have a, new to me, 1990 Glastron Seirra with a Mercruiser 4.3 and a Alpha one outdrive. The boat actually has a trim up/down switch and a tilt up/down switch. The trim switch is on the inside of the throttle/gear leaver and the tilt is on the outside of the leaver. The tilt up/down works, but only the trim down works. Neither trim or tilt work with the key off. I would think that at least the tilt would. It does look like somebody may have messed with the wiring at the switch. I can not seem to find a wiring diagram of this exact switch. Any help would be greatly appreciated. Thanks.
