I've found some great posts on here that show removing the spacer to replace the drive belt which I've done.
Only problem is I seem to have a second smaller pulley on the top (I assume for power steering even though that doesn't exist) which results in not enough room between the center of the motor mount to slip the belt in.
Do I need to remove that center pulley?
tks,
tks,
