Bought this boat in July, and had it out a few times this summer, and it runs pretty good. However, not knowing much history, now that the boating season is over, I wanted to pull the engine for a winter refresh project. At least one exhaust manifold has a crack, and it didn't idle the best (probably needs a carb rebuild), and I get a little oil film in the bilge area too. Figured I would pull it, strip it down to the short block, and replace all the seals, etc. Well, that was the plan anyway.
Upon getting the exhaust manifolds off, I was able to see something that I was not very happy about.
It's just below the head mating surface on the block. The "Napa" sticker you see is the starter, and the black tube is the dipstick tube.
The engine actually runs really well, and has good compression numbers: 165, 170, 165, 165, 180, 180
Has anyone ever taken a block to get welded up? Or am I just being cheap? Obviously from the rust the crack is into the water jacket, but it can't be too bad or I'd see a much bigger stain there. I also didn't observe any water leaking down on that side of the engine, unlike the other side which had the bad exhaust manifold.
It is the original 4.3l engine for this 1988 Sea Ray, so it is 23 years old, with no signs of having ever been pulled - serial number was in the owners manual - OC326690, and matches the tag on the back of the engine.
If replacement is the only answer, I'm considering going Jimmy/S10 hunting to find a rebuildable core engine. Just need to stay in that 1988-1992 time frame, right?
